Wat je nodig hebt
The Sony Cradle Audio System will have 14 XXXX type of screws located on the bottom of the device.
Using a Phillips #2 screwdriver, remove all 14 screws.
Once all of the screws are removed, the cover can be taken off using a metal spudger.
There are 8 more XXXX screws holding the circuit board in place that will need to be removed.
Once the screws are removed, a plastic spudger can be used to carefully move the circuit board away from the device.
Gereedschap gebruikt in deze stap:Tweezers$4.99
The wire furthest to the left of the device can be removed in the same way that he first was removed. Simply squeeze the clip and pull out.
The final wire (furthest to the right) can be carefully removed using a pair of tweezers.
Now the circuit board has been completely removed from the device and can be set aside.
