Inleiding
Use this guide if the speakers do not turn on and you think it is because the power cord in the subwoofer is broken.
Wat je nodig hebt
Remove fourteen 8 mm Phillips #2 screws from the bottom of the subwoofer.
Once all of the screws are removed, the cover can be taken off using a metal spudger.
Remove four 8 mm Phillips #2 screws.
Detach the air tube from the side panel.
Bijna klaar!
Conclusie
