Ga door naar hoofdinhoud
Sony CFD-8 Speaker Replacement
Wat je nodig hebt
  1. Sony CFD-8 Speaker Replacement, Front Panel: stap 1, afbeelding 1 van 3 Sony CFD-8 Speaker Replacement, Front Panel: stap 1, afbeelding 2 van 3 Sony CFD-8 Speaker Replacement, Front Panel: stap 1, afbeelding 3 van 3
    • Hold the boombox handle at an angle to access the screws behind the CD player.
    • Use a Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
  2. Sony CFD-8 Speaker Replacement: stap 2, afbeelding 1 van 2 Sony CFD-8 Speaker Replacement: stap 2, afbeelding 2 van 2
    • Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images.
    • All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
  3. Sony CFD-8 Speaker Replacement: stap 3, afbeelding 1 van 3 Sony CFD-8 Speaker Replacement: stap 3, afbeelding 2 van 3 Sony CFD-8 Speaker Replacement: stap 3, afbeelding 3 van 3
    • Gently separate the front panel from the back panel.
    • Remove the two connections holding the front panel to boombox.
    • One connection is located on the upper left hand side of the main circuit board.
    • The other is a large white strip slightly to the right of the cassette player.
    • Do not touch the cylindrical parts on the circuit board. These are capacitors and may deliver a shock!
    • Remove the front panel.
  4. Sony CFD-8 Speaker Replacement, Speaker: stap 4, afbeelding 1 van 2 Sony CFD-8 Speaker Replacement, Speaker: stap 4, afbeelding 2 van 2
    • Use a 14cm Phillips #1 screwdriver to remove the four respective screws attaching the left and right speakers to the front panel.
  5. Sony CFD-8 Speaker Replacement: stap 5, afbeelding 1 van 1
    • Remove the speakers from the front panel.
Conclusie
Liam Kirsh
197 Reputatie
1 Handleiding geschreven
Cal Poly, Team 10-38, Amido Fall 2014 Lid van Cal Poly, Team 10-38, Amido Fall 2014
CPSU-AMIDO-F14S10G38
5 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 17
Altijd: 3,301
