Ga door naar hoofdinhoud
Sony CFD-8 LCD Board Replacement
Wat je nodig hebt
  1. Sony CFD-8 LCD Board Replacement, Battery: stap 1, afbeelding 1 van 3 Sony CFD-8 LCD Board Replacement, Battery: stap 1, afbeelding 2 van 3 Sony CFD-8 LCD Board Replacement, Battery: stap 1, afbeelding 3 van 3
    • Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps.
    • Be sure to unplug the boombox from the wall before attempting to open it for repair.
  2. Sony CFD-8 LCD Board Replacement: stap 2, afbeelding 1 van 2 Sony CFD-8 LCD Board Replacement: stap 2, afbeelding 2 van 2
    • Push against the positive end of each battery. Once it is loose, lift the battery out. Repeat for all six batteries.
    • The top row of batteries have the positive side pointing right. The bottom row of batteries have the positive side pointing left.
  3. Sony CFD-8 LCD Board Replacement, Front Panel: stap 3, afbeelding 1 van 3 Sony CFD-8 LCD Board Replacement, Front Panel: stap 3, afbeelding 2 van 3 Sony CFD-8 LCD Board Replacement, Front Panel: stap 3, afbeelding 3 van 3
    • Hold the boombox handle at an angle to access the screws behind the CD player.
    • Use a Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
  4. Sony CFD-8 LCD Board Replacement: stap 4, afbeelding 1 van 2 Sony CFD-8 LCD Board Replacement: stap 4, afbeelding 2 van 2
    • Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images.
    • All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
  5. Sony CFD-8 LCD Board Replacement: stap 5, afbeelding 1 van 3 Sony CFD-8 LCD Board Replacement: stap 5, afbeelding 2 van 3 Sony CFD-8 LCD Board Replacement: stap 5, afbeelding 3 van 3
    • Gently separate the front panel from the back panel.
    • Remove the two connections holding the front panel to boombox.
    • One connection is located on the upper left hand side of the main circuit board.
    • The other is a large white strip slightly to the right of the cassette player.
    • Do not touch the cylindrical parts on the circuit board. These are capacitors and may deliver a shock!
    • Remove the front panel.
  6. Sony CFD-8 LCD Board Replacement, LCD Board: stap 6, afbeelding 1 van 1
    • Remove three 5mm screws from the back of the circuit board with a Phillips #1 screwdriver.
  7. Sony CFD-8 LCD Board Replacement: stap 7, afbeelding 1 van 1
    • Remove the circuit board.
Conclusie
Andrew Kleve
271 Reputatie
2 handleidingen geschreven
Cal Poly, Team 10-38, Amido Fall 2014 Lid van Cal Poly, Team 10-38, Amido Fall 2014
CPSU-AMIDO-F14S10G38
5 Leden
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 643
