Inleiding
We turn our devices on and off every single day, and as such, the buttons wear over time. This repair guide will focus on replacing the electrical components controlling the On/Off buttons.
Wat je nodig hebt
Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
Using a spudger, carefully remove the metal casing that is attached to the ZIF connector.
