Ga door naar hoofdinhoud
Sony Bloggie 3D Player Battery Replacement
Wat je nodig hebt
  1. Sony Bloggie 3D Player Battery Replacement, Front Cover: stap 1, afbeelding 1 van 1
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Sony Bloggie 3D Player Battery Replacement: stap 2, afbeelding 1 van 2 Sony Bloggie 3D Player Battery Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Sony Bloggie 3D Player Battery Replacement, Back Cover: stap 3, afbeelding 1 van 2 Sony Bloggie 3D Player Battery Replacement, Back Cover: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
  4. Sony Bloggie 3D Player Battery Replacement: stap 4, afbeelding 1 van 2 Sony Bloggie 3D Player Battery Replacement: stap 4, afbeelding 2 van 2
    • Use a plastic opening tool to loosen the back cover off the device.
    • Once the back cover is loose, remove it gently by hand.
  5. Sony Bloggie 3D Player Battery Replacement, Battery: stap 5, afbeelding 1 van 2 Sony Bloggie 3D Player Battery Replacement, Battery: stap 5, afbeelding 2 van 2
    • Remove the battery with your fingers.
Conclusie
Timothy Tran
1 Reputatie
2 handleidingen geschreven
Cal Poly, Team 7-12, Maness Winter 2013 Lid van Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 Leden
12 handleidingen geschreven
Één opmerking
You forgot to mention the need to flip the screen up (a screw holds it down) in order to get to a screw holding the back cover. Other than that, thank you for the info.
Rich Brewer - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 22
Altijd: 2,177
