Ga door naar hoofdinhoud
Sony Betamovie BMC-220 Cassette Compartment Replacement
Wat je nodig hebt
  1. Sony Betamovie BMC-220 Cassette Compartment Replacement, Battery: stap 1, afbeelding 1 van 3 Sony Betamovie BMC-220 Cassette Compartment Replacement, Battery: stap 1, afbeelding 2 van 3 Sony Betamovie BMC-220 Cassette Compartment Replacement, Battery: stap 1, afbeelding 3 van 3
    • Orient your Betamovie so that the back of the device is sitting flat, and the bottom of the device is facing you.
    • Slide the RELEASE switch up to bring the hand drip down.
  2. Sony Betamovie BMC-220 Cassette Compartment Replacement: stap 2, afbeelding 1 van 3 Sony Betamovie BMC-220 Cassette Compartment Replacement: stap 2, afbeelding 2 van 3 Sony Betamovie BMC-220 Cassette Compartment Replacement: stap 2, afbeelding 3 van 3
    • Turn the BATTERY knob to OPEN, and open the lid.
    • Reminder: When inserting a new battery, make sure the knob is turned to OPEN.
    • Be careful not to point the hand grip down when turning the BATTERY knob. The battery pack may fall out.
  3. Sony Betamovie BMC-220 Cassette Compartment Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery from the Betamovie.
  4. Sony Betamovie BMC-220 Cassette Compartment Replacement, Cassette Compartment: stap 4, afbeelding 1 van 3 Sony Betamovie BMC-220 Cassette Compartment Replacement, Cassette Compartment: stap 4, afbeelding 2 van 3 Sony Betamovie BMC-220 Cassette Compartment Replacement, Cassette Compartment: stap 4, afbeelding 3 van 3
    • Remove the two screws (2mm x 6mm) at the base of the Cassette compartment using the Phillips #1 screwdriver.
    • Remove the two screws (2mm x 6mm) at the back of the Betamovie using the Phillips #2 screwdriver.
    • Once all of the screws are removed, pop the cassette cover off of the camera.
  5. Sony Betamovie BMC-220 Cassette Compartment Replacement: stap 5, afbeelding 1 van 2 Sony Betamovie BMC-220 Cassette Compartment Replacement: stap 5, afbeelding 2 van 2
    • Remove the silver piece at the top of the Betamovie using your hands.
    • Remove the two screws (2mm x 6mm) under the flat silver piece using the Phillips #1 screwdriver. The silver metal clip comes off once the crews are removed.
  6. Sony Betamovie BMC-220 Cassette Compartment Replacement: stap 6, afbeelding 1 van 2 Sony Betamovie BMC-220 Cassette Compartment Replacement: stap 6, afbeelding 2 van 2
    • Remove the two screws (2mm x 6mm) underneath the cassette compartment on the bottom of the Betamovie with the Phillips #1 screwdriver.
    • Remove the bottom piece of the cassette compartment.
Conclusie
Mary McLaughlin
198 Reputatie
1 Handleiding geschreven
Één opmerking
Do you know how to take out the Trinicon tube in this camera?
Kyle Gilchrist - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 635
