Inleiding
Open up the optical drive and take it apart until you get to the motor. This guide is a bit more difficult than simply unscrewing, but definitely doable. Also, you get to see the inside of the optical drive, which is pretty cool.
Wat je nodig hebt
Remove the 12mm screws with the Philips #2 screwdriver which keep the plastic panels in place.
Don't forget, there are two more 12mm screws on the other side as well.
Remove the two 10mm silver screws holding the front panel on with the Phillips #2 screwdriver, located on the top side of the front panel.
Take off the front panel by depressing the clips (either with your fingers, screwdriver, or other small object) and pulling it off.
Unscrew the two metal clamps on both sides of the optical drive by removing three sets of screws:
The two 10mm silver screws on the bottom of the each clamp.
The 10mm silver screw holding each clamp from the front.
The two 5mm black screws on the sides.
Remove the two clamps. They can be removed by hand.
Set aside the rest of the blu ray player; the only part you will need for this guide is the optical drive.
Één andere persoon heeft deze handleiding voltooid.
