Ga door naar hoofdinhoud
Sony BDP-BX620 Port Board Replacement
Wat je nodig hebt
  1. Sony BDP-BX620 Port Board Replacement, Outer Cover: stap 1, afbeelding 1 van 2 Sony BDP-BX620 Port Board Replacement, Outer Cover: stap 1, afbeelding 2 van 2
    • Power on the device, eject the disk tray, and power off the device.
    • Turn the device over.
    • Lightly apply downward pressure on the black covering on the disk tray until it comes off.
    • Caution, applying too much pressure can break the black covering.
  2. Sony BDP-BX620 Port Board Replacement: stap 2, afbeelding 1 van 2 Sony BDP-BX620 Port Board Replacement: stap 2, afbeelding 2 van 2
    • Turn the device around.
    • Using a Phillips screw driver, remove the screws on both ends of the device circled red in the image.
    • Slide the side covers on either side towards the back of the device.
    • There is a back cover on either side of the device.
  3. Sony BDP-BX620 Port Board Replacement: stap 3, afbeelding 1 van 3 Sony BDP-BX620 Port Board Replacement: stap 3, afbeelding 2 van 3 Sony BDP-BX620 Port Board Replacement: stap 3, afbeelding 3 van 3
    • This step might require someone to help unclasping the plastic clips.
    • Turn the device so that the bottom is facing up.
    • In the bottom, unclip the three plastic clips circled in red.
    • On either side, unclip the plastic clip circled in red
    • Slide the black covering forwards to remove.
    • All five clips have to be unclasped for the covering to be removed.
    • Careful not to break the plastic clips when putting it back on.
  4. Sony BDP-BX620 Port Board Replacement, Port Board: stap 4, afbeelding 1 van 2 Sony BDP-BX620 Port Board Replacement, Port Board: stap 4, afbeelding 2 van 2
    • Now, spot the large ribbon cable that connects between the motherboard and the port board.
    • Remove the cable by pulling upwards.
    • Be careful when pulling upwards on the ribbon cable. Too much force can cause it to rip.
  5. Sony BDP-BX620 Port Board Replacement: stap 5, afbeelding 1 van 1
    • Use your Phillips screwdriver to take out the silver screw holding in the port board.
  6. Sony BDP-BX620 Port Board Replacement: stap 6, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Now use the tweezers to unclip the portboard on the side.
Conclusie
Zachery Zavala
175 Reputatie
2 handleidingen geschreven
USF Tampa, Team 1-6, Lacy Fall 2016 Lid van USF Tampa, Team 1-6, Lacy Fall 2016
USFT-LACY-F16S1G6
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 161
