Ga door naar hoofdinhoud
Sony BDP-BX520 Disc Reader Replacement
Wat je nodig hebt
  1. Sony BDP-BX520 Disc Reader Replacement, Disc Tray Cover: stap 1, afbeelding 1 van 1
    • Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
    • Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
  2. Sony BDP-BX520 Disc Reader Replacement: stap 2, afbeelding 1 van 1
    • Grab the sides of the disc tray cover and carefully pull each side upwards, starting with the left side. This will unhook the cover from the tray.
  3. Sony BDP-BX520 Disc Reader Replacement: stap 3, afbeelding 1 van 1
    • Close the disc tray, then power off and unplug the Blu-Ray player.
  4. Sony BDP-BX520 Disc Reader Replacement, Top Case: stap 4, afbeelding 1 van 1
    • Locate the three 8 mm screws on the back of the Blu-Ray player.
    • Using the Phillips #2 screwdriver, unscrew each of the screws and set them aside.
  5. Sony BDP-BX520 Disc Reader Replacement: stap 5, afbeelding 1 van 2 Sony BDP-BX520 Disc Reader Replacement: stap 5, afbeelding 2 van 2
    • Gently pull the top case back to remove it from the Blu-Ray player.
  6. Sony BDP-BX520 Disc Reader Replacement, Front Panel: stap 6, afbeelding 1 van 1
    • Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
    • Lifting these clips may require you to hold one clip open while you move on to the next clip.
  7. Sony BDP-BX520 Disc Reader Replacement: stap 7, afbeelding 1 van 1
    • Flip device over so the bottom faces you.
    • Insert the nylon or metal spudger and lift the two clips on the bottom of the device.
  8. Sony BDP-BX520 Disc Reader Replacement: stap 8, afbeelding 1 van 1
    • Lift the clip on the opposite side of the device with the nylon or metal spudger.
  9. Sony BDP-BX520 Disc Reader Replacement: stap 9, afbeelding 1 van 2 Sony BDP-BX520 Disc Reader Replacement: stap 9, afbeelding 2 van 2
    • Grasp the front case firmly and lift from the rest of the device.
    • Lifting may require some force.
  10. Sony BDP-BX520 Disc Reader Replacement, Disc Reader: stap 10, afbeelding 1 van 1
    • Do not touch the circuit boards or the internal parts of the device while it is powered on. This could short out the circuits and possibly cause you harm.
    • Plug in the device and power it on by pushing the right button on the front of the device. The light should turn on.
  11. Sony BDP-BX520 Disc Reader Replacement: stap 11, afbeelding 1 van 1
    • Eject the disc tray by pushing the left button on the front of the device.
    • Unplug the device once the disc tray is open.
  12. Sony BDP-BX520 Disc Reader Replacement: stap 12, afbeelding 1 van 1
    • Insert the nylon or metal spudger under the clip and lift it up. There are 4 clips that need to be lifted, two on each side
  13. Sony BDP-BX520 Disc Reader Replacement: stap 13, afbeelding 1 van 2 Sony BDP-BX520 Disc Reader Replacement: stap 13, afbeelding 2 van 2
    • Once the clips are free, lift the top cover of the disc tray up.
    • This should take minimal force.
  14. Sony BDP-BX520 Disc Reader Replacement: stap 14, afbeelding 1 van 1
    • Unscrew the two silver 8mm Phillips 1 screws from the disc reader.
  15. Sony BDP-BX520 Disc Reader Replacement: stap 15, afbeelding 1 van 3 Sony BDP-BX520 Disc Reader Replacement: stap 15, afbeelding 2 van 3 Sony BDP-BX520 Disc Reader Replacement: stap 15, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the tweezers to lift both sides of the black clip holding the white 14 pin ribbon in place.
    • Once free the white 24 pin ribbon should slip right out.
  16. Sony BDP-BX520 Disc Reader Replacement: stap 16, afbeelding 1 van 2 Sony BDP-BX520 Disc Reader Replacement: stap 16, afbeelding 2 van 2
    • Carefully lift up the disc reader. It is still attached by a cable underneath!
  17. Sony BDP-BX520 Disc Reader Replacement: stap 17, afbeelding 1 van 2 Sony BDP-BX520 Disc Reader Replacement: stap 17, afbeelding 2 van 2
    • Gently pull out the white 13 pin cable from the disc reader.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kyle Smit
243 Reputatie
2 handleidingen geschreven
Cal Poly, Team 8-41, Amido Winter 2015 Lid van Cal Poly, Team 8-41, Amido Winter 2015
CPSU-AMIDO-W15S8G41
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 1,262
