Inleiding
This guide will help you remove the outer cover of your Sony BDP-BX510 so that you can start the replacement steps in the other guides.
Wat je nodig hebt
Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
To remove the tray cover, hold both sides of the tray cover and gently apply a downward pressure.
Apply slightly more pressure to the left side until it unhooks then unhook the right side.
Close the disk tray by pressing the eject button again, then power off the device and unplug it.
