Ga door naar hoofdinhoud
Sony BDP-BX510 Outer Cover Replacement
Wat je nodig hebt
  1. Sony BDP-BX510 Outer Cover Replacement, Outer Cover: stap 1, afbeelding 1 van 1
    • Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
  2. Sony BDP-BX510 Outer Cover Replacement: stap 2, afbeelding 1 van 2 Sony BDP-BX510 Outer Cover Replacement: stap 2, afbeelding 2 van 2
    • To remove the tray cover, hold both sides of the tray cover and gently apply a downward pressure.
    • Apply slightly more pressure to the left side until it unhooks then unhook the right side.
    • Close the disk tray by pressing the eject button again, then power off the device and unplug it.
    • Do not use too much force to remove the tray cover as you may break it.
  3. Sony BDP-BX510 Outer Cover Replacement: stap 3, afbeelding 1 van 2 Sony BDP-BX510 Outer Cover Replacement: stap 3, afbeelding 2 van 2
    • Turn to the back of the device.
    • Remove the two 7mm Phillips #2 screws.
    • Slide the two plastic covers on both sides of the device towards the back of the device to remove them.
  4. Sony BDP-BX510 Outer Cover Replacement: stap 4, afbeelding 1 van 3 Sony BDP-BX510 Outer Cover Replacement: stap 4, afbeelding 2 van 3 Sony BDP-BX510 Outer Cover Replacement: stap 4, afbeelding 3 van 3
    • Turn the device so you can see the bottom.
    • Unclip the three black plastic clips on the bottom of the device.
    • Unclip one clip on each side of the device.
  5. Sony BDP-BX510 Outer Cover Replacement: stap 5, afbeelding 1 van 1
    • Slide the cover forward to remove.
Conclusie
Niki Ngosi
375 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 173
