Ga door naar hoofdinhoud
Sony BDP-BX510 Motherboard Replacement
Wat je nodig hebt
  1. Sony BDP-BX510 Motherboard Replacement, Outer Cover: stap 1, afbeelding 1 van 1
    • Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
  2. Sony BDP-BX510 Motherboard Replacement: stap 2, afbeelding 1 van 2 Sony BDP-BX510 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • To remove the tray cover, hold both sides of the tray cover and gently apply a downward pressure.
    • Apply slightly more pressure to the left side until it unhooks then unhook the right side.
    • Close the disk tray by pressing the eject button again, then power off the device and unplug it.
    • Do not use too much force to remove the tray cover as you may break it.
  3. Sony BDP-BX510 Motherboard Replacement: stap 3, afbeelding 1 van 2 Sony BDP-BX510 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Turn to the back of the device.
    • Remove the two 7mm Phillips #2 screws.
    • Slide the two plastic covers on both sides of the device towards the back of the device to remove them.
  4. Sony BDP-BX510 Motherboard Replacement: stap 4, afbeelding 1 van 3 Sony BDP-BX510 Motherboard Replacement: stap 4, afbeelding 2 van 3 Sony BDP-BX510 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Turn the device so you can see the bottom.
    • Unclip the three black plastic clips on the bottom of the device.
    • Unclip one clip on each side of the device.
  5. Sony BDP-BX510 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Slide the cover forward to remove.
  6. Sony BDP-BX510 Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Pull out the power cord from the device.
  7. Sony BDP-BX510 Motherboard Replacement: stap 7, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Pull out these cables from the motherboard.
    • Using tweezers, lift the black tab on the connector of the large 45 pin connector on the motherboard.
    • Pull the large 45 pin ribbon cable out of the connector in the motherboard.
    • Do not use excessive force to remove the cables and do not forcibly pull out the 45 pin ribbon cable as you could damage it. Once the black tab is lifted it should come out easily.
  8. Sony BDP-BX510 Motherboard Replacement: stap 8, afbeelding 1 van 2 Sony BDP-BX510 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Remove the two 5mm Phillips #1 screws.
    • Lift the side of the power module and remove it.
  9. Sony BDP-BX510 Motherboard Replacement: stap 9, afbeelding 1 van 2 Sony BDP-BX510 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Remove the three 5mm Phillips #1 screws.
    • Turn the device over to the backside.
    • Use tweezers or metal spudger to take off the metal clasp for the metal brace near the center on the bottom of the device.
    • Remove the metal brace.
  10. Sony BDP-BX510 Motherboard Replacement: stap 10, afbeelding 1 van 3 Sony BDP-BX510 Motherboard Replacement: stap 10, afbeelding 2 van 3 Sony BDP-BX510 Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Remove the silver 3mm Phillips #1 screw.
    • Remove the black 7mm Phillips #1 screw.
    • Lift the side of the motherboard and pull it out.
Conclusie
Tae (Tim) Im
279 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 212
