Ga door naar hoofdinhoud
Sony Alpha a7s II Tripod Mount Replacement
Wat je nodig hebt
  1. Sony Alpha a7s II Tripod Mount Replacement, Tripod Mount: stap 1, afbeelding 1 van 2 Sony Alpha a7s II Tripod Mount Replacement, Tripod Mount: stap 1, afbeelding 2 van 2
    • Orient your camera so that you are looking at the bottom portion.
    • Using a JIS #00 screwdriver, remove the 7 screws that are securing the metal plate to the bottom of your camera.
    • You do not need to remove that recessed screw that is not connected to the bottom metal plate.
  2. Sony Alpha a7s II Tripod Mount Replacement: stap 2, afbeelding 1 van 1
    • Remove metal plate. Sometimes this plate can become stuck and hard to remove. Use tweezers to separate the plate from the bottom of the camera.
  3. Sony Alpha a7s II Tripod Mount Replacement: stap 3, afbeelding 1 van 1
    • Flip the plate to the opposite side exposing the aspect that was just inside of the camera.
    • Use the JIS #00 screwdriver to unscrew the the 3 screws surrounding the tripod mount.
  4. Sony Alpha a7s II Tripod Mount Replacement: stap 4, afbeelding 1 van 1
    • Remove the tripod mount from the metal plate.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 44
Altijd: 2,615
