Ga door naar hoofdinhoud
Sony Alpha a7s II Diopter Replacement
Wat je nodig hebt
  1. Sony Alpha a7s II Diopter Replacement, Diopter: stap 1, afbeelding 1 van 1
    • Orient your camera so that you are looking at the posterior portion.
  2. Sony Alpha a7s II Diopter Replacement: stap 2, afbeelding 1 van 1
    • Place each of your thumbs on the interior portions of the eyepiece cup, pressing down and pushing up.
  3. Sony Alpha a7s II Diopter Replacement: stap 3, afbeelding 1 van 1
    • Slide the eyepiece off by carefully pulling it upward.
    • Be careful not to come into contact with the viewfinder lens as the lens can be easily scratched.
  4. Sony Alpha a7s II Diopter Replacement: stap 4, afbeelding 1 van 1
    • Remove the screw from the middle of the diopter with the JIS #00 screwdriver.
  5. Sony Alpha a7s II Diopter Replacement: stap 5, afbeelding 1 van 1
    • Remove the diopter with your hands. If the diopter is at all stuck you can use the pointed tweezers to help aid in the removal process.
    • Be careful not to let fingers or tweezers come into contact with the viewfinder lens as the lens can be easily scratched.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 34
Altijd: 2,069
