Inleiding
For this guide you will be replacing the motherboard for a Sony SLT-A55V. In order replace this part you will need precision set of screw drivers, and a set of plastic opening tools to "pop" open the clips.
We have not found an inexpensive supplier for this part. It may be cheaper to purchase a used or broken SLT-A55V for parts.
Wat je nodig hebt
Remove the focusing knob (indicated in red) located on the back of the camera to the right of the viewfinder.
Once the back of the camera is removed the motherboard is exposed.
Remove all ribbon cables that are connected to the motherboard.
There are two ribbon cables that are stacked; the location is marked in orange. One cable is connected under the board, while the other is connected to the top
8 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
Hi Mr Almunif
I have a SONY ALPHA SLT A55V that stopped working.
Sony South Africa quoted ZAR 17, 000 to repair this camera when the latest model over here will cost me ZAR 25, 000
Sony indicated that the camera needs a new Main PC Board and a Shutter Charge Unit or Shutter Change unit. Not sure from their handwriting on the quote
I can buy a new PC on ebay but need to find a charge unit
Can you assist with this and also on how to replace it
My previous A55 was stolen and the one I have is much needed to take videos of the properties that I sell for clients. m in the real estate business in South Africa
Regards
Chris Breet
