Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Turn the camera off by switching the power knob "OFF" text to the white selector dot.
Flip the camera upside-down and carefully place it on a flat surface.
With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
Push the latch to the right to unlock the battery compartment. The door should flip upward.
With the compartment open, locate a blue tab shown with spudger
Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
3 opmerkingen
Battery Stuck
Will not spring out. Any ideas?
Got it, battery damaged. Tapped on edge to remove battery
