Ga door naar hoofdinhoud
Sony Alpha NEX-6 Battery Replacement
Wat je nodig hebt
    1. Sony Alpha NEX-6 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
      • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
      • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony Alpha NEX-6 Battery Replacement: stap 2, afbeelding 1 van 1
      • Flip the camera upside-down and carefully place it on a flat surface.
      • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
      • Push the latch to the right to unlock the battery compartment. The door should flip upward.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony Alpha NEX-6 Battery Replacement: stap 3, afbeelding 1 van 1
      • With the compartment open, locate a blue tab shown with spudger
      • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Clayton Dale
1.067 Reputatie
7 handleidingen geschreven
USF Tampa, Team 11-2, Blackwell Winter 2015 Lid van USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 Leden
14 handleidingen geschreven
3Gids Commentaar
Battery Stuck
rustychinnis - Antwoord Deel
Will not spring out. Any ideas?
Got it, battery damaged. Tapped on edge to remove battery
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 33
Altijd: 3,047
