Inleiding
To replace the camera image sensor, the majority of the device will need to be taken apart. Organization will be crucial in order to reconstruct the device, and make the camera work properly. This repair may be needed if your device is capturing photographs that appear completely black, or contains random patches of light.
Wat je nodig hebt
Unscrew the 3 silver 1.2 mm Phillips #000 screws from the bottom of the camera.
Pull off the metal back from the device body.
Locate a thin metal piece on top of the motherboard, and unscrew 4 silver 1.2 mm Phillips #000 screws in the corners of the metal piece.
Underneath. you will locate the motherboard.
The tripod piece will be loose. Take the piece from the device and set it off to the side.
Lift the gray plastic camera piece surrounding the motherboard up.
Leave the long, thin ribbon cable that runs along the gray piece attached. It is not necessary to detach.
Lift up the motherboard to reveal one final thin ribbon cable connected to a white retaining tab underneath the motherboard.
Flip up the white retaining tab, and utilize tweezers to pull out the final thin ribbon cable.
3 andere personen hebben deze handleiding voltooid.
