Ga door naar hoofdinhoud
Sony Alpha NEX-5N Battery Replacement
  1. Sony Alpha NEX-5N Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before operating on this device, be sure the device is turned off.
    • Turn the device off by switching the power knob to face the word "OFF".
  2. Sony Alpha NEX-5N Battery Replacement: stap 2, afbeelding 1 van 2 Sony Alpha NEX-5N Battery Replacement: stap 2, afbeelding 2 van 2
    • Flip the device upside-down and gently place it down on a flat surface.
    • Locate the battery compartment, which is indicated by a grooved latch.
    • Push the latch to the right so that the arrow is positioned above the word "Open". The door should then flip upward.
  3. Sony Alpha NEX-5N Battery Replacement: stap 3, afbeelding 1 van 2 Sony Alpha NEX-5N Battery Replacement: stap 3, afbeelding 2 van 2
    • With the battery compartment latch open, locate the lock lever.
    • Press the lock lever to the left. This will eject the camera battery.
Conclusie
Demi Deletang
101 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 99
Altijd: 3,795
