Ga door naar hoofdinhoud
Sony Alpha NEX-5N Battery Replacement
  1. Sony Alpha NEX-5N Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before operating on this device, be sure the device is turned off.
    • Turn the device off by switching the power knob to face the word "OFF".
    Vraag FixBot
    Voeg opmerking toe
  2. Sony Alpha NEX-5N Battery Replacement: stap 2, afbeelding 1 van 2 Sony Alpha NEX-5N Battery Replacement: stap 2, afbeelding 2 van 2
    • Flip the device upside-down and gently place it down on a flat surface.
    • Locate the battery compartment, which is indicated by a grooved latch.
    • Push the latch to the right so that the arrow is positioned above the word "Open". The door should then flip upward.
    Vraag FixBot
    Voeg opmerking toe
  3. Sony Alpha NEX-5N Battery Replacement: stap 3, afbeelding 1 van 2 Sony Alpha NEX-5N Battery Replacement: stap 3, afbeelding 2 van 2
    • With the battery compartment latch open, locate the lock lever.
    • Press the lock lever to the left. This will eject the camera battery.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Demi Deletang
101 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 82
Altijd: 3,843
