Inleiding
We'll only replace the metal plate of the battery cover without having to replace the full cover.
By replacing only the metal plate, there's no need to disassemble the camera, which would void the warranty on the product.
Video overzicht
As they do not sell the plate alone, it is necessary to buy the complete door, I did it on eBay.com
Since we received the spare part, we removed the plate from the new door, for this we put a very small flat screwdriver in the marked slot and pushed towards the side of the hinge.
We take the pin (safe) of the new door and place it in the original door in the chamber.
We put the metal plate on the original door and ready.
To reassemble your device, follow these instructions in reverse.
4 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
3 opmerkingen
Me funciono perfectamente!! gracias
Very helpful. I was trying to figure out how to replace the entire cover but could not realize how to remove it since there's no easy way to access the metal pin. But moving the parts from the new to the old cover worked perfect! I needed quite a bit of force to remove the metal lid, but once done it was easy. Thanks for this tutorial!
Device disassembly cannot void your warranty in the US unless you actually break something in the process.
