Ga door naar hoofdinhoud
Sony Alpha ILCE-6000 Lens Replacement
Wat je nodig hebt
  1. Sony Alpha ILCE-6000 Lens Replacement, Lens: stap 1, afbeelding 1 van 1
    • Turn of camera by turning the switch to OFF.
  2. Sony Alpha ILCE-6000 Lens Replacement: stap 2, afbeelding 1 van 1
    • Use the finger, press and hold the release black circle button ( on the bottom ) next to the lens on the front of the camera.
  3. Sony Alpha ILCE-6000 Lens Replacement: stap 3, afbeelding 1 van 2 Sony Alpha ILCE-6000 Lens Replacement: stap 3, afbeelding 2 van 2
    • Using the left hand or the right hand to hold the camera body, other hand twist the lens counterclockwise and pull it off.
    • Align the white dot of the lens to the white dot on the camera mount to completely replace.
Conclusie
Vuong Nguyen
122 Reputatie
1 Handleiding geschreven
UW Tacoma, Team 1-4, Rose Winter 2017 Lid van UW Tacoma, Team 1-4, Rose Winter 2017
UWT-ROSE-W17S1G4
4 Leden
10 handleidingen geschreven
Één opmerking
my camera will not recognize my lens, optical steady shot 1650. it used to work fine, but I dropped it. now the camera says it's not attached properly. any suggestions?
Connie - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 38
Altijd: 1,954
