Ga door naar hoofdinhoud
Sony Alpha ILCE-6000 E-mount Replacement
Wat je nodig hebt
  1. Sony Alpha ILCE-6000 E-mount Replacement, Lens: stap 1, afbeelding 1 van 1
    • Turn of camera by turning the switch to OFF.
  2. Sony Alpha ILCE-6000 E-mount Replacement: stap 2, afbeelding 1 van 1
    • Use the finger, press and hold the release black circle button ( on the bottom ) next to the lens on the front of the camera.
  3. Sony Alpha ILCE-6000 E-mount Replacement: stap 3, afbeelding 1 van 2 Sony Alpha ILCE-6000 E-mount Replacement: stap 3, afbeelding 2 van 2
    • Using the left hand or the right hand to hold the camera body, other hand twist the lens counterclockwise and pull it off.
    • Align the white dot of the lens to the white dot on the camera mount to completely replace.
  4. Sony Alpha ILCE-6000 E-mount Replacement, E-mount Replacement: stap 4, afbeelding 1 van 2 Sony Alpha ILCE-6000 E-mount Replacement, E-mount Replacement: stap 4, afbeelding 2 van 2
    • Locate the E-mount on the front of the camera
  5. Sony Alpha ILCE-6000 E-mount Replacement: stap 5, afbeelding 1 van 3 Sony Alpha ILCE-6000 E-mount Replacement: stap 5, afbeelding 2 van 3 Sony Alpha ILCE-6000 E-mount Replacement: stap 5, afbeelding 3 van 3
    • Take a Philips head 00 screw to remove the four of the 5.1mm screws located on the E-mount.
  6. Sony Alpha ILCE-6000 E-mount Replacement: stap 6, afbeelding 1 van 3 Sony Alpha ILCE-6000 E-mount Replacement: stap 6, afbeelding 2 van 3 Sony Alpha ILCE-6000 E-mount Replacement: stap 6, afbeelding 3 van 3
    • After removing the screws, pull off the E-mount metal ring gently and wiggle it until its free.
    • Remove the plastic ring located under the metal ring.
    • Do not remove the metal piece that is located behind the plastic ring.
  7. Sony Alpha ILCE-6000 E-mount Replacement: stap 7, afbeelding 1 van 1
    • Replace the plastic E-mount ring with a new one.
Conclusie
Yirga Yilma
221 Reputatie
2 handleidingen geschreven
UW Tacoma, Team 1-4, Rose Winter 2017 Lid van UW Tacoma, Team 1-4, Rose Winter 2017
UWT-ROSE-W17S1G4
4 Leden
10 handleidingen geschreven
2 opmerkingen
Hello folks,
actually I have to replace the E-mount ring my ILCE-6000, which seems very easy with this description. Thanks a lot for this!
Is the ring available anywhere on this globe? I would truly appreciate any hint.
Best regards, JDK
JDK - Antwoord
Hi there, found a source for the ring as original part. The price is reasonable. Now waiting for delivery ...
Best regards, JDK
JDK - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 84
Altijd: 3,622
