Inleiding
This guide will go through step by step on the replacement of the motherboard on a Sony Alpha A350. These steps will include removal of all screws, wires, ribbon strips, eye cup, front case, and rear case of the camera in order to safely pull the motherboard out of the main device. The motherboard plays an important role in image processing and it has a major influence on the quality of the eventual image that is produced. The motherboard will need replaced if the camera is not powering or turning on. (Especially if the camera has been subjected to outside trauma such as a drop or water damage.) Replacing the motherboard will help in fixing the camera to work again.
Wat je nodig hebt
Using a Phillips #00 Screwdriver, remove the four 5.5mm screws from the bottom of the camera.
Using a Phillips #00 Screwdriver, remove the one 4.3mm screw.
Identify the bottom of the eye cup
Using the heavy duty spudger, push the eye cup upward to remove it from the camera body.
Using a Phillips #00 screwdriver, remove the two 4.3mm screws attaching the ribbons to the front case.
After opening the case up and exposing the motherboard, remove five 3.6 mm screws with a Phillips #00 screwdriver from the board.
Één andere persoon heeft deze handleiding voltooid.
