Ga door naar hoofdinhoud
Sony Alpha A350 Front Case Replacement
Wat je nodig hebt
  1. Sony Alpha A350 Front Case Replacement, Front Case: stap 1, afbeelding 1 van 2 Sony Alpha A350 Front Case Replacement, Front Case: stap 1, afbeelding 2 van 2
    • Using a Phillips #00 Screwdriver, remove the four 5.5mm screws from the bottom of the camera.
    • Using a Phillips #00 Screwdriver, remove the one 4.3mm screw.
  2. Sony Alpha A350 Front Case Replacement: stap 2, afbeelding 1 van 2 Sony Alpha A350 Front Case Replacement: stap 2, afbeelding 2 van 2
    • Using a Phillips #00 screwdriver, remove one 3.6mm screw on the left side of the camera.
    • Open the remote / DC under the rubber flap to reveal a screw.
    • Using the Phillips #00 screwdriver, remove one 4.3mm screw.
  3. Sony Alpha A350 Front Case Replacement: stap 3, afbeelding 1 van 2 Sony Alpha A350 Front Case Replacement: stap 3, afbeelding 2 van 2
    • Open the flash on the top of the camera and remove two 4.3mm screws with a Phillips #00 screwdriver.
    • If the spring guard falls out during deconstruction, gently place the guard over the spring during construction.
    • To open the flash, simply press the button on the left side.
  4. Sony Alpha A350 Front Case Replacement: stap 4, afbeelding 1 van 2 Sony Alpha A350 Front Case Replacement: stap 4, afbeelding 2 van 2
    • Open the plastic SD card door.
    • Using Phillips #00 screwdriver, remove two 4.4 mm screws outside and two 4.4mm screws inside the door.
  5. Sony Alpha A350 Front Case Replacement: stap 5, afbeelding 1 van 2 Sony Alpha A350 Front Case Replacement: stap 5, afbeelding 2 van 2
    • Gently pull the outer front case from the camera.
    • It should fall apart easily if all screws are removed.
Conclusie
Danielle Trivett
337 Reputatie
3 handleidingen geschreven
IUPUI, Team S1-G6, Henning Fall 2019 Lid van IUPUI, Team S1-G6, Henning Fall 2019
IUPUI-HENNING-F19S1G6
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 709
