Ga door naar hoofdinhoud
Sony Alpha A3000 Built-in flash Replacement
Wat je nodig hebt
  1. Sony Alpha A3000 Built-in flash Replacement, Rear Case: stap 1, afbeelding 1 van 3 Sony Alpha A3000 Built-in flash Replacement, Rear Case: stap 1, afbeelding 2 van 3 Sony Alpha A3000 Built-in flash Replacement, Rear Case: stap 1, afbeelding 3 van 3
    • Remove the seven highlighted screws shown here.
    • Screws are teeny tiny, don't lose them!
    Vraag FixBot
    Voeg opmerking toe
  2. Sony Alpha A3000 Built-in flash Replacement: stap 2, afbeelding 1 van 2 Sony Alpha A3000 Built-in flash Replacement: stap 2, afbeelding 2 van 2
    • Remove this final screw from the memory card compartment.
    • Remove the chassis by pulling the back cover away from the camera.
    • Be careful not to damage any of the delicate ribbon cables when removing the chassis.
    Vraag FixBot
    Voeg opmerking toe
  3. Sony Alpha A3000 Built-in flash Replacement: stap 3, afbeelding 1 van 2 Sony Alpha A3000 Built-in flash Replacement: stap 3, afbeelding 2 van 2
    • Gently but forcefully lift up on the parallel cable connecting the two halves of the camera.
    Vraag FixBot
    Voeg opmerking toe
  4. Sony Alpha A3000 Built-in flash Replacement, Built-in flash: stap 4, afbeelding 1 van 1
    • Remove the single screw from the bottom of the flash device.
    Vraag FixBot
    Voeg opmerking toe
  5. Sony Alpha A3000 Built-in flash Replacement: stap 5, afbeelding 1 van 1
    • Remove the flash cover by gently pulling it in an outward direction.
    Vraag FixBot
    Voeg opmerking toe
  6. Sony Alpha A3000 Built-in flash Replacement: stap 6, afbeelding 1 van 1
    • Use a soldering tool to remove the three wires connecting the flash to the camera.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Leonard Holloman
662 Reputatie
4 handleidingen geschreven
USF Tampa, Team 4-4, Meier Fall 2015 Lid van USF Tampa, Team 4-4, Meier Fall 2015
USFT-MEIER-F15S4G4
4 Leden
10 handleidingen geschreven
4Gids Commentaar
Thx, saved me from draing costs for cleaning my viewfinder from watercolor paint. also hotshoe adapter disassembly was easier than other parts. be careful, if you want to do it!
Michael Smith - Antwoord Deel
My LCD and viewfinder are not working anymore. I think is the flex that broke up... or the socket where is connected... And there is no replacement pieces in my country.......... As well as it is not a cheap camera for us........ I want to kill myself.........................
l2weenlive - Antwoord Deel
Any procedure for SONY a6300 built-in flash replacement?
Vivek Dhar - Antwoord Deel
hi, i see this thread a bit old. has someone replaced the focus assist light (that orange tint ?LED?).
mine missing since i have my cam. regardless of menu setting, it never lighted up.
dont have clue, how deeply should blow up, till access.
Levente Likhanecz - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 69
Altijd: 2,631
