Ga door naar hoofdinhoud
Sony Alpha 5100 Front Plate Replacement
    1. Sony Alpha 5100 Front Plate Replacement, Battery: stap 1, afbeelding 1 van 2 Sony Alpha 5100 Front Plate Replacement, Battery: stap 1, afbeelding 2 van 2
      • Slide the power switch on the top of the camera to "off."
      • Turn the camera over to the bottom, and push the latch towards the side marked "open" to release the battery cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony Alpha 5100 Front Plate Replacement: stap 2, afbeelding 1 van 1
      • Push the blue spring-loaded lever to release the battery.
      • Remove the battery from the camera.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony Alpha 5100 Front Plate Replacement, Front Plate: stap 3, afbeelding 1 van 3 Sony Alpha 5100 Front Plate Replacement, Front Plate: stap 3, afbeelding 2 van 3 Sony Alpha 5100 Front Plate Replacement, Front Plate: stap 3, afbeelding 3 van 3
      • Remove one 2mm Phillips #00 screw from the flash plate cover.
      • Use the spudger to pop the plate off.
      • Remove two 2mm Phillips #00 screws on the side of the camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony Alpha 5100 Front Plate Replacement: stap 4, afbeelding 1 van 2 Sony Alpha 5100 Front Plate Replacement: stap 4, afbeelding 2 van 2
      • Pop the memory card door open by gently lifting the door up.
      • Remove two 2mm Phillips #00 screws from the side of the camera.
      • Remove three 2mm Phillips #00 screws on the bottom of the camera.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony Alpha 5100 Front Plate Replacement: stap 5, afbeelding 1 van 2 Sony Alpha 5100 Front Plate Replacement: stap 5, afbeelding 2 van 2
      • Use the opening tool to gently pop the front plate apart from the body.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Kevin Raggiani
444 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S4-G6, Saloman Fall 2019 Lid van UMass Dartmouth, Team S4-G6, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G6
3 Leden
8 handleidingen geschreven
2Gids Commentaar
Hi, i need to access the shutter-on/off switch on my a5100. Which parts and screws do i need to take apart.?
Thank you,
Fabian,
Fabian - Antwoord Deel
Step 4 is missing one screw. Pop the flash and there is a screw there sideways that must come out.
Nick P - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 45
Altijd: 2,270
