Ga door naar hoofdinhoud
Sony Action Cam Mini HDR-AZ1 Gasket Replacement
Wat je nodig hebt
  1. Sony Action Cam Mini HDR-AZ1 Gasket Replacement, Gasket Seal: stap 1, afbeelding 1 van 2 Sony Action Cam Mini HDR-AZ1 Gasket Replacement, Gasket Seal: stap 1, afbeelding 2 van 2
    • To open the case, slide the tab located on the underside of the case to the “unlock” position.
    • Press in the tabs, that are on the sides of the unlock tab, and pull down. This should cause the lid to open.
    • Remove the lid.
  2. Sony Action Cam Mini HDR-AZ1 Gasket Replacement: stap 2, afbeelding 1 van 1
    • Using the plastic opening tool, wedge it between the O-Ring and the groove.
    • Move the tool around the ring, prying the gasket from the groove, until it is able to be grabbed.
  3. Sony Action Cam Mini HDR-AZ1 Gasket Replacement: stap 3, afbeelding 1 van 1
    • Remove the O-Ring from the lid of the case.
Conclusie
To place a new gasket in, follow these steps in reverse order, making sure the gasket is fully pushed back in around its entire perimeter.
Mathieu LaFond
425 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 Lid van UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G7
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 554
