Ga door naar hoofdinhoud
Sony Action Cam Mini HDR-AZ1 Battery Door Replacement
Wat je nodig hebt
  1. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery: stap 1, afbeelding 1 van 3 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery: stap 1, afbeelding 2 van 3 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery: stap 1, afbeelding 3 van 3
    • To access the battery, first make sure the camera is out of the case.
    • Push down on the door lock, located on the rear of the action cam.
    • The door is unlocked if the little yellow square is showing.
    • Pull on the panel door, located on the side opposite the LCD screen, and it should now pop open.
  2. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: stap 2, afbeelding 1 van 3 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: stap 2, afbeelding 2 van 3 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: stap 2, afbeelding 3 van 3
    • Open the side panel outward to reveal the battery.
    • Be sure not to break the small piece of plastic securing the door to the camera.
    • Use the pull tab to pop the battery out of place.
  3. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery Door: stap 3, afbeelding 1 van 2 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery Door: stap 3, afbeelding 2 van 2
    • Remove the circled 4 millimeter black screw adjacent to where the door is attached.
  4. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: stap 4, afbeelding 1 van 2 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: stap 4, afbeelding 2 van 2
    • Grab the small black bracket holding the ribbon on which the door is attached and pull it out.
  5. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: stap 5, afbeelding 1 van 1
    • Pull the door straight back so the attaching ribbon is pulled taught and the door will come right off.
Conclusie
Mathieu LaFond
425 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 Lid van UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G7
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 709
