Ga door naar hoofdinhoud
Sony Action Cam HDR-AS15 O-Ring Replacement
Wat je nodig hebt
  1. Sony Action Cam HDR-AS15 O-Ring Replacement, Open the Waterproof Case: stap 1, afbeelding 1 van 1
    • To open the case, push the yellow "Open" tab located at the bottom of the case.
    • Pull out on the yellow tabs as indicated by the circles in the photo to unlock the lid. This may be a little tricky!
    • Then, remove the lid.
  2. Sony Action Cam HDR-AS15 O-Ring Replacement, Pry the O-ring from the Groove: stap 2, afbeelding 1 van 1
    • Take the plastic opening tool and wedge it between the O-ring and the groove.
    • Then, pry the O-ring until it is out of the groove.
  3. Sony Action Cam HDR-AS15 O-Ring Replacement, Remove the O-ring: stap 3, afbeelding 1 van 1
    • Now that the O-ring is out of the groove, remove the O-ring from the lid.
Conclusie
Justin Calean
421 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-2, Sullivan Winter 2015 Lid van USF Tampa, Team 1-2, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G2
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 893
