Ga door naar hoofdinhoud
Sony Action Cam HDR-AS15 Memory Card Replacement
  1. Sony Action Cam HDR-AS15 Memory Card Replacement, Getting to the Memory Card: stap 1, afbeelding 1 van 1
    • To access the memory card, push left on the rear of the Action Cam. The rear panel should easily slide to the side.
  2. Sony Action Cam HDR-AS15 Memory Card Replacement, Removing the card: stap 2, afbeelding 1 van 1
    • After sliding the rear panel to the side, open the door outward to reveal the memory card slot and battery tray.
    • Push in on the back of the memory card with the tip of your finger until you feel a click.
    • Pinch the rear of the memory card that is protruding from the slot and pull on it until the memory card is removed.
Conclusie
Justin Calean
421 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-2, Sullivan Winter 2015 Lid van USF Tampa, Team 1-2, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G2
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 680
