Ga door naar hoofdinhoud
Sony AZ1VR Lens O Ring Replacement
Wat je nodig hebt
  1. Sony AZ1VR Lens O Ring Replacement, Lens O Ring: stap 1, afbeelding 1 van 3 Sony AZ1VR Lens O Ring Replacement, Lens O Ring: stap 1, afbeelding 2 van 3 Sony AZ1VR Lens O Ring Replacement, Lens O Ring: stap 1, afbeelding 3 van 3
    • Start by removing the two screws on the bottom, and the screw inside the battery room.
    • Once these are removed, slide the door out, and the small piece of plastic with the door.
    Vraag FixBot
  2. Sony AZ1VR Lens O Ring Replacement: stap 2, afbeelding 1 van 3 Sony AZ1VR Lens O Ring Replacement: stap 2, afbeelding 2 van 3 Sony AZ1VR Lens O Ring Replacement: stap 2, afbeelding 3 van 3
    • Now, grab the lens and pull the body out of the plastic, this will reveal the insides of the device.
    • You'll see a screw on the top of the device, towards the front, remove this screw.
    • Next pull the tabs on the bottom and top of the lens, and pull outward, this will remove the lens housing from the body.
    Vraag FixBot
  3. Sony AZ1VR Lens O Ring Replacement: stap 3, afbeelding 1 van 1
    • Next, you'll see a white ring around the lens, slowly remove that ring without causing damage to the device.
    • Now put the new one in its place. Now reassemble the device, it's all set to be used.
    Vraag FixBot
Conclusie
Michael Martin
401 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S3-G5, Botvin Spring 2017 Lid van UMass Dartmouth, Team S3-G5, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G5
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 16
Altijd: 444
