Inleiding
The viewfinder glass helps you frame the scene before taking the photo. A broken viewfinder glass will affect your ability to compose good pictures. This guide will walk you through the replacement of a broken viewfinder glass. Ensure that the problem with your viewfinder is not software related, and verify that the focus feature is working properly before considering replacement. The tools required for this replacement are a JIS 0 screwdriver, JIS 00 screwdriver, JIS 000 screwdriver, opening tools, spudger, and tweezers.
Wat je nodig hebt
From the top of the camera remove one 4mm JIS 00 screw.
Remove one 5mm JIS 00 screw and the plastic bushing around it.
Remove the viewfinder's protective cover.
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
This really helped me. I changed my VF unit with no problem. And btw, it is not necessary to unplug LCD cable. I havent done it, as i thought it would be really tricky to put it back in and it was just alright. Just tape the display to back panel while manipulating it so you dont twist the cables.
Thanks for this
Where can I get the viewfinder glass though
