Ga door naar hoofdinhoud
Sony α6500 Top Assembly Replacement
Wat je nodig hebt
  1. Sony α6500 Top Assembly Replacement, Battery: stap 1, afbeelding 1 van 1
    • Verify the camera is powered off by setting the switch to OFF.
  2. Sony α6500 Top Assembly Replacement: stap 2, afbeelding 1 van 2 Sony α6500 Top Assembly Replacement: stap 2, afbeelding 2 van 2
    • Flip the camera upside down.
    • Slide the battery compartment lock to OPEN to unlock it.
  3. Sony α6500 Top Assembly Replacement: stap 3, afbeelding 1 van 2 Sony α6500 Top Assembly Replacement: stap 3, afbeelding 2 van 2
    • Push the blue lever aside to release the battery.
  4. Sony α6500 Top Assembly Replacement: stap 4, afbeelding 1 van 1
    • Remove the released battery from the compartment.
  5. Sony α6500 Top Assembly Replacement, Top Assembly: stap 5, afbeelding 1 van 2 Sony α6500 Top Assembly Replacement, Top Assembly: stap 5, afbeelding 2 van 2
    • To access the back of the camera remove the screws attaching the LCD screen hinge to the camera body.
    • Remove four 3 mm JIS 000 screws.
    • Remove one 3 mm JIS 00 screw.
    • After dismounting the screen hinge be careful to avoid tearing the black wire ribbon connecting the screen to the camera body.
  6. Sony α6500 Top Assembly Replacement: stap 6, afbeelding 1 van 2 Sony α6500 Top Assembly Replacement: stap 6, afbeelding 2 van 2
    • Grasp the viewfinder eyecup; slide it up and off the viewfinder.
  7. Sony α6500 Top Assembly Replacement: stap 7, afbeelding 1 van 3 Sony α6500 Top Assembly Replacement: stap 7, afbeelding 2 van 3 Sony α6500 Top Assembly Replacement: stap 7, afbeelding 3 van 3
    • Press the flash popup button on the back of the camera.
    • Remove one 5 mm JIS 00 screw from inside the flash compartment.
    • Remove one 4 mm JIS 00 screw.
  8. Sony α6500 Top Assembly Replacement: stap 8, afbeelding 1 van 3 Sony α6500 Top Assembly Replacement: stap 8, afbeelding 2 van 3 Sony α6500 Top Assembly Replacement: stap 8, afbeelding 3 van 3
    • To remove the top of the camera you must remove the back first.
    • Remove the 2.5 mm JIS 00 screw from the side of the camera near the viewfinder.
    • Use the opening tool to pry off the small cover.
    • Remove two 2.5 mm JIS 00 screws from underneath the cover.
    • Remove a 5 mm JIS 00 screw from underneath the cover.
  9. Sony α6500 Top Assembly Replacement: stap 9, afbeelding 1 van 2 Sony α6500 Top Assembly Replacement: stap 9, afbeelding 2 van 2
    • Remove three 2.5 mm JIS 0 screws from the back face of the camera.
    • Remove one 4 mm JIS 00 screw from the underside of the lip that overhangs the back of the camera.
  10. Sony α6500 Top Assembly Replacement: stap 10, afbeelding 1 van 1
    • Remove four 4 mm JIS 0 screws from the bottom of the camera.
  11. Sony α6500 Top Assembly Replacement: stap 11, afbeelding 1 van 2 Sony α6500 Top Assembly Replacement: stap 11, afbeelding 2 van 2
    • Flip the battery lock switch to open and open the battery compartment.
    • Remove three 2.5 mm JIS 00 screws from the top of the battery compartment.
    • You may need a longer or thinner screwdriver to reach the screws in the battery compartment.
  12. Sony α6500 Top Assembly Replacement: stap 12, afbeelding 1 van 2 Sony α6500 Top Assembly Replacement: stap 12, afbeelding 2 van 2
    • Use the plastic opening tool to begin prying off the back of the camera from the side.
    • Continue to loosen the back until you can open it from the bottom.
  13. Sony α6500 Top Assembly Replacement: stap 13, afbeelding 1 van 3 Sony α6500 Top Assembly Replacement: stap 13, afbeelding 2 van 3 Sony α6500 Top Assembly Replacement: stap 13, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Open the back of the camera.
    • Use tweezers to remove two ribbon connectors from underneath the back. One connects to the LCD display and the other connects to the right side behind the battery compartment.
    • Ribbon connectors can tear easily. Grasp the plastic ends (not the ribbon) when removing.
  14. Sony α6500 Top Assembly Replacement: stap 14, afbeelding 1 van 3 Sony α6500 Top Assembly Replacement: stap 14, afbeelding 2 van 3 Sony α6500 Top Assembly Replacement: stap 14, afbeelding 3 van 3
    • Use the plastic opening tool to peel down the rubber grip around the handle at least 1 cm.
    • The adhesive holding the rubber grip down should be strong enough to reattach when you are done. If not, you may need an adhesive to reglue it.
    • Remove one 3 mm JIS 000 screw from underneath the rubber grip on the right side.
    • Remove one 4 mm JIS 000 screw from the left side.
  15. Sony α6500 Top Assembly Replacement: stap 15, afbeelding 1 van 2 Sony α6500 Top Assembly Replacement: stap 15, afbeelding 2 van 2
    • The last screws holding the top on can be accessed once the back of the camera is removed.
    • Remove one 2.5 mm JIS 00 screw from the top next to the flash mount.
  16. Sony α6500 Top Assembly Replacement: stap 16, afbeelding 1 van 3 Sony α6500 Top Assembly Replacement: stap 16, afbeelding 2 van 3 Sony α6500 Top Assembly Replacement: stap 16, afbeelding 3 van 3
    • Insert a long, thin JIS 00 screwdriver through the two holes and into the battery compartment; remove the two 5mm JIS 00 screws inside it.
  17. Sony α6500 Top Assembly Replacement: stap 17, afbeelding 1 van 2 Sony α6500 Top Assembly Replacement: stap 17, afbeelding 2 van 2
    • Use the long, thin, screwdriver to remove one 5 mm JIS 00 screw inside the camera accessible below the dials from the back.
  18. Sony α6500 Top Assembly Replacement: stap 18, afbeelding 1 van 3 Sony α6500 Top Assembly Replacement: stap 18, afbeelding 2 van 3 Sony α6500 Top Assembly Replacement: stap 18, afbeelding 3 van 3
    • Use the plastic opening tool to gently lift up the shutter button assembly.
    • Grasp the front grip from the top and bottom and pull it off. It should come off easily with the shutter button out of the way.
    • The shutter button will still be attached by one ribbon cable once the front grip is removed.
  19. Sony α6500 Top Assembly Replacement: stap 19, afbeelding 1 van 3 Sony α6500 Top Assembly Replacement: stap 19, afbeelding 2 van 3 Sony α6500 Top Assembly Replacement: stap 19, afbeelding 3 van 3
    • Remove one 2.5 mm JIS 00 screw from where the shutter button assembly used to be.
    • Remove one 3 mm JIS 00 screw from the side of the camera.
  20. Sony α6500 Top Assembly Replacement: stap 20, afbeelding 1 van 2 Sony α6500 Top Assembly Replacement: stap 20, afbeelding 2 van 2
    • Carefully unplug the two ribbon connectors attaching the top assembly to the rest of the camera.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Micah Fitzgerald
644 Reputatie
2 handleidingen geschreven
Cal Poly, Team S11-G5, Regan Fall 2019 Lid van Cal Poly, Team S11-G5, Regan Fall 2019
CPSU-REGAN-F19S11G5
5 Leden
14 handleidingen geschreven
Één opmerking
Do you know where i should buy this? Especially in Indonesia.
Dimasngehe - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 1,300
