Ga door naar hoofdinhoud
Sonos Playbase Side Speaker Replacement
Wat je nodig hebt
  1. Sonos Playbase Side Speaker Replacement, Bottom Panel: stap 1, afbeelding 1 van 3 Sonos Playbase Side Speaker Replacement, Bottom Panel: stap 1, afbeelding 2 van 3 Sonos Playbase Side Speaker Replacement, Bottom Panel: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Pro Tech Toolkit
    $74.95
    Koop
    • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
    • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
    • Melt the adhesive with an iOpener for ease of opening
    • Use a Metal Spudger if the plastic spudgers do not work.
    • Take care to avoid damaging the plastic or the device if using a metal spudger.
  2. Sonos Playbase Side Speaker Replacement: stap 2, afbeelding 1 van 2 Sonos Playbase Side Speaker Replacement: stap 2, afbeelding 2 van 2
    Pro Tech Toolkit
    $74.95
    Koop
    • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
    • Remove the seven 44mm T-20 screws by turning counter-clockwise.
    • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
    • Record where each screw belongs for easier reassembly.
  3. Sonos Playbase Side Speaker Replacement: stap 3, afbeelding 1 van 2 Sonos Playbase Side Speaker Replacement: stap 3, afbeelding 2 van 2
    Pro Tech Toolkit
    $74.95
    Koop
    • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
    • Use a metal spudger if plastic openers do not work.
  4. Sonos Playbase Side Speaker Replacement, Side Speakers: stap 4, afbeelding 1 van 3 Sonos Playbase Side Speaker Replacement, Side Speakers: stap 4, afbeelding 2 van 3 Sonos Playbase Side Speaker Replacement, Side Speakers: stap 4, afbeelding 3 van 3
    Pro Tech Toolkit
    $74.95
    Koop
    • Remove the 24 mm T-10 screw by turning counter clockwise.
    • Remove the 41 mm T-55 screw by turning counter clockwise.
  5. Sonos Playbase Side Speaker Replacement: stap 5, afbeelding 1 van 3 Sonos Playbase Side Speaker Replacement: stap 5, afbeelding 2 van 3 Sonos Playbase Side Speaker Replacement: stap 5, afbeelding 3 van 3
  6. Sonos Playbase Side Speaker Replacement: stap 6, afbeelding 1 van 2 Sonos Playbase Side Speaker Replacement: stap 6, afbeelding 2 van 2
    • Remove the speaker.
Conclusie
James Andrews
421 Reputatie
4 handleidingen geschreven
Cal Poly, Team S17-G2, White Fall 2018 Lid van Cal Poly, Team S17-G2, White Fall 2018
CPSU-WHITE-F18S17G2
4 Leden
8 handleidingen geschreven
Één opmerking
Where can you get a replacement speaker/driver?
Christopher Erickson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 797
