Ga door naar hoofdinhoud
Sonos Playbase IR Reciver Replacement
Wat je nodig hebt
  1. Sonos Playbase IR Reciver Replacement, Bottom Panel: stap 1, afbeelding 1 van 3 Sonos Playbase IR Reciver Replacement, Bottom Panel: stap 1, afbeelding 2 van 3 Sonos Playbase IR Reciver Replacement, Bottom Panel: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Pro Tech Toolkit
    $74.95
    Koop
    • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
    • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
    • Melt the adhesive with an iOpener for ease of opening
    • Use a Metal Spudger if the plastic spudgers do not work.
    • Take care to avoid damaging the plastic or the device if using a metal spudger.
  2. Sonos Playbase IR Reciver Replacement: stap 2, afbeelding 1 van 2 Sonos Playbase IR Reciver Replacement: stap 2, afbeelding 2 van 2
    Pro Tech Toolkit
    $74.95
    Koop
    • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
    • Remove the seven 44mm T-20 screws by turning counter-clockwise.
    • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
    • Record where each screw belongs for easier reassembly.
  3. Sonos Playbase IR Reciver Replacement: stap 3, afbeelding 1 van 2 Sonos Playbase IR Reciver Replacement: stap 3, afbeelding 2 van 2
    Pro Tech Toolkit
    $74.95
    Koop
    • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
    • Use a metal spudger if plastic openers do not work.
  4. Sonos Playbase IR Reciver Replacement, Main Speaker Array: stap 4, afbeelding 1 van 2 Sonos Playbase IR Reciver Replacement, Main Speaker Array: stap 4, afbeelding 2 van 2
  5. Sonos Playbase IR Reciver Replacement: stap 5, afbeelding 1 van 2 Sonos Playbase IR Reciver Replacement: stap 5, afbeelding 2 van 2
    • Remove the side speakers from the green printed circuit board (PCB) running along the top of the main speaker array by pinching and pulling out the connector.
    • See Recognizing & Disconnecting Cable Connectors for more information.
  6. Sonos Playbase IR Reciver Replacement: stap 6, afbeelding 1 van 3 Sonos Playbase IR Reciver Replacement: stap 6, afbeelding 2 van 3 Sonos Playbase IR Reciver Replacement: stap 6, afbeelding 3 van 3
    Pro Tech Toolkit
    $74.95
    Koop
    • Remove the two 16mm T-20 screws located on both sides of the main speaker array by turning counter-clockwise.
  7. Sonos Playbase IR Reciver Replacement: stap 7, afbeelding 1 van 1
    • Remove the main speaker array by gripping it on both sides and pulling it out.
    • The array may require a significant amount of force to remove.
    • Use prying tools as necessary to remove the main speaker array if you are unsuccessful using your hands.
    • Do not to yank the array out too suddenly or too far as this may damage the device.
  8. Sonos Playbase IR Reciver Replacement: stap 8, afbeelding 1 van 1
    • Prop the removed main speaker array up on top of the main circuit board.
  9. Sonos Playbase IR Reciver Replacement, IR Receiver: stap 9, afbeelding 1 van 3 Sonos Playbase IR Reciver Replacement, IR Receiver: stap 9, afbeelding 2 van 3 Sonos Playbase IR Reciver Replacement, IR Receiver: stap 9, afbeelding 3 van 3
    Pro Tech Toolkit
    $74.95
    Koop
    • Lift the main speaker array to reveal the IR receiver underneath.
    • Remove the three 11 mm T-5 screws by turning counter-clockwise.
  10. Sonos Playbase IR Reciver Replacement: stap 10, afbeelding 1 van 3 Sonos Playbase IR Reciver Replacement: stap 10, afbeelding 2 van 3 Sonos Playbase IR Reciver Replacement: stap 10, afbeelding 3 van 3
  11. Sonos Playbase IR Reciver Replacement: stap 11, afbeelding 1 van 2 Sonos Playbase IR Reciver Replacement: stap 11, afbeelding 2 van 2
    • Remove the IR receiver by grasping it with two fingers and pulling up.
Conclusie
George Slivka
339 Reputatie
3 handleidingen geschreven
Cal Poly, Team S17-G2, White Fall 2018 Lid van Cal Poly, Team S17-G2, White Fall 2018
CPSU-WHITE-F18S17G2
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 1,145
