Ga door naar hoofdinhoud
Sonos Playbase Ethernet Port Replacement
Wat je nodig hebt
  1. Sonos Playbase Ethernet Port Replacement, Bottom Panel: stap 1, afbeelding 1 van 3 Sonos Playbase Ethernet Port Replacement, Bottom Panel: stap 1, afbeelding 2 van 3 Sonos Playbase Ethernet Port Replacement, Bottom Panel: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Pro Tech Toolkit
    $74.95
    Koop
    • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
    • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
    • Melt the adhesive with an iOpener for ease of opening
    • Use a Metal Spudger if the plastic spudgers do not work.
    • Take care to avoid damaging the plastic or the device if using a metal spudger.
  2. Sonos Playbase Ethernet Port Replacement: stap 2, afbeelding 1 van 2 Sonos Playbase Ethernet Port Replacement: stap 2, afbeelding 2 van 2
    Pro Tech Toolkit
    $74.95
    Koop
    • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
    • Remove the seven 44mm T-20 screws by turning counter-clockwise.
    • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
    • Record where each screw belongs for easier reassembly.
  3. Sonos Playbase Ethernet Port Replacement: stap 3, afbeelding 1 van 2 Sonos Playbase Ethernet Port Replacement: stap 3, afbeelding 2 van 2
    Pro Tech Toolkit
    $74.95
    Koop
    • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
    • Use a metal spudger if plastic openers do not work.
  4. Sonos Playbase Ethernet Port Replacement, Ethernet Port: stap 4, afbeelding 1 van 2 Sonos Playbase Ethernet Port Replacement, Ethernet Port: stap 4, afbeelding 2 van 2
    • Unplug the Ethernet Port from the main circuit board by pinching the white clip and pulling upward.
  5. Sonos Playbase Ethernet Port Replacement: stap 5, afbeelding 1 van 2 Sonos Playbase Ethernet Port Replacement: stap 5, afbeelding 2 van 2
    Pro Tech Toolkit
    $74.95
    Koop
    • Remove the two 18 mm T-10 screws holding the Ethernet Port in place by turning them counterclockwise.
  6. Sonos Playbase Ethernet Port Replacement: stap 6, afbeelding 1 van 2 Sonos Playbase Ethernet Port Replacement: stap 6, afbeelding 2 van 2
    • Remove the Ethernet Port from the housing by pinching from both sides and pulling it out.
Conclusie
James Andrews
421 Reputatie
4 handleidingen geschreven
Cal Poly, Team S17-G2, White Fall 2018 Lid van Cal Poly, Team S17-G2, White Fall 2018
CPSU-WHITE-F18S17G2
4 Leden
8 handleidingen geschreven
Één opmerking
I actually have a broken ethernet port on a playbase. Do you have any idea where I can buy a replacement port?
Thanks,
D
david paler - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 12
Altijd: 1,434
