Inleiding
Prerequisite Only
Wat je nodig hebt
Use the metal spudger to pry open the front grill. Little force will be needed to wedge the metal spudger into the crevice.
After the grill has been loosened on all edges. Use your fingers as a wedge and gently pull the grill off the speaker. This will reveal the front speaker panel.
Use a pointed metal spudger to remove the rubber plugs covering the screws in the bottom left and right corners of the speaker panel.
Insert the spudger against the side of the rubber plug and the speaker panel while leveraging upward.
Remove the eight 12 mm Phillips #1 screws bordering the front speaker panel.
With a #1 Phillips-head screwdriver, remove the eight 12mm screws on the bottom panel.
We have marked the original placement of the warranty stickers in orange. To remove use a pair of tweezers to grip onto the sticker and pull with a gentle upward motion
Één andere persoon heeft deze handleiding voltooid.
