Ga door naar hoofdinhoud
Sonos Play 5 Audio/Control Board Replacement
Wat je nodig hebt
  1. Sonos Play 5 Audio/Control Board Replacement, Front Panel Assembly: stap 1, afbeelding 1 van 1
    • Disconnect any power to the speaker and wait a few minutes for the capacitors to fully discharge.
    • Flip the speaker upside down.
    • There may be a rubber foot covering the bottom screws (not included in picture). Remove this by pulling up from one of the corners using a spudger.
  2. Sonos Play 5 Audio/Control Board Replacement: stap 2, afbeelding 1 van 2 Sonos Play 5 Audio/Control Board Replacement: stap 2, afbeelding 2 van 2
    • Remove eight 10mm Phillips #2 screws
    • Remove the bottom panel by pulling upwards.
    • Be very gentle with the ends of the three antennas. They are very fragile.
  3. Sonos Play 5 Audio/Control Board Replacement: stap 3, afbeelding 1 van 3 Sonos Play 5 Audio/Control Board Replacement: stap 3, afbeelding 2 van 3 Sonos Play 5 Audio/Control Board Replacement: stap 3, afbeelding 3 van 3
    • Flip the device so that the grille is facing up.
    • Locate the line on the right side of the speaker where the grill and the plastic meet, and place your plastic opening tool in the gap.
    • Run the spudger along the gap, loosening the grille from the plastic. Repeat this process on the left side as well.
    • Gently pull up on the grille, removing it from the front panel.
  4. Sonos Play 5 Audio/Control Board Replacement: stap 4, afbeelding 1 van 1
    • Remove the six 8mm Phillips #2 screws.
    • Remove the two 10mm Phillips #2 screws.
  5. Sonos Play 5 Audio/Control Board Replacement: stap 5, afbeelding 1 van 2 Sonos Play 5 Audio/Control Board Replacement: stap 5, afbeelding 2 van 2
    • Locate the line on the right side where the front panel and back panel meet. Place a plastic opening tool in the gap, and run it along the gap. Repeat this on the left side.
    • Use the opening tool to lift the front plate. If a plastic tool is not providing enough leverage, use a metal opening tool.
    • Gently pull up on the face plate to ensure it has been detached from the enclosure.
    • When pulling on the face plate be cautious because it is still connected by wires on the back of the plate.
  6. Sonos Play 5 Audio/Control Board Replacement: stap 6, afbeelding 1 van 3 Sonos Play 5 Audio/Control Board Replacement: stap 6, afbeelding 2 van 3 Sonos Play 5 Audio/Control Board Replacement: stap 6, afbeelding 3 van 3
    • Lift up the front panel, forming a 90 degree angle with the back panel. Locate the locate ten pin connector shown. This is the wire that connects the front panel to back panel.
    • Press down on the small tab located on the connector. With the tab firmly pressed down, pull the connector out from its socket.
    • The faceplate assembly is now fully detached from the rest of the speaker.
  7. Sonos Play 5 Audio/Control Board Replacement, Motherboard: stap 7, afbeelding 1 van 3 Sonos Play 5 Audio/Control Board Replacement, Motherboard: stap 7, afbeelding 2 van 3 Sonos Play 5 Audio/Control Board Replacement, Motherboard: stap 7, afbeelding 3 van 3
    • Remove the ten pin connector.
  8. Sonos Play 5 Audio/Control Board Replacement: stap 8, afbeelding 1 van 1
    • Flip the device over on its front side.
  9. Sonos Play 5 Audio/Control Board Replacement: stap 9, afbeelding 1 van 1
    • Remove six 5mm Phillips #0 screws.
    • Remove two 7mm Phillips #2 screws.
  10. Sonos Play 5 Audio/Control Board Replacement: stap 10, afbeelding 1 van 1
    • Flip the device on its back.
  11. Sonos Play 5 Audio/Control Board Replacement: stap 11, afbeelding 1 van 3 Sonos Play 5 Audio/Control Board Replacement: stap 11, afbeelding 2 van 3 Sonos Play 5 Audio/Control Board Replacement: stap 11, afbeelding 3 van 3
    • Remove the grey and red antenna connectors by lifting them away from the board.
    • Pull cords away from the board.
  12. Sonos Play 5 Audio/Control Board Replacement: stap 12, afbeelding 1 van 2 Sonos Play 5 Audio/Control Board Replacement: stap 12, afbeelding 2 van 2
    • Remove the yellow antenna connector by lifting it away from the board.
    • Pull cord away from the board.
  13. Sonos Play 5 Audio/Control Board Replacement: stap 13, afbeelding 1 van 3 Sonos Play 5 Audio/Control Board Replacement: stap 13, afbeelding 2 van 3 Sonos Play 5 Audio/Control Board Replacement: stap 13, afbeelding 3 van 3
    • Remove circuit board by lifting it straight away from the rear plate.
  14. Sonos Play 5 Audio/Control Board Replacement, Audio/Control Board: stap 14, afbeelding 1 van 1
    • Lay the two connected boards so that the power board is facing upwards
  15. Sonos Play 5 Audio/Control Board Replacement: stap 15, afbeelding 1 van 2 Sonos Play 5 Audio/Control Board Replacement: stap 15, afbeelding 2 van 2
    • Unscrew Four Phillips #2 bolts
    • These bolts will not come out, but will pull out of the nuts on the other side of the board
  16. Sonos Play 5 Audio/Control Board Replacement: stap 16, afbeelding 1 van 1
    • Flip boards so audio board is facing upwards, as is shown in picture
  17. Sonos Play 5 Audio/Control Board Replacement: stap 17, afbeelding 1 van 3 Sonos Play 5 Audio/Control Board Replacement: stap 17, afbeelding 2 van 3 Sonos Play 5 Audio/Control Board Replacement: stap 17, afbeelding 3 van 3
    • Lift control board up and away from power supply board
  18. Sonos Play 5 Audio/Control Board Replacement: stap 18, afbeelding 1 van 1
    • The smaller of the two boards is the audio/control board.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Warren Willingham
996 Reputatie
3 handleidingen geschreven
USF Tampa, Team S3-G6, Sullivan Spring 2017 Lid van USF Tampa, Team S3-G6, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G6
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 47
Altijd: 5,695
