Inleiding
A tweeter creates a crisp and accurate high-frequency sound. If the device tweeter is not working, the tweeter may be damaged and may need to be replaced. This guide will demonstrate how to replace the tweeter.
Wat je nodig hebt
Remove the four 9 mm Torx Security #9 head screws. There are two on each side.
Using a plastic opening tool, remove the grey tape from both sides of the device.
Remove the two 9mm Torx #9 screws fastening the power cable to the housing.
Remove the power cable.
Using a metal spudger, press down on the clips that lock the input wires to the amplifier.
Once unlocked, pull back on the wires to remove them.
3 opmerkingen
Can anybody recommend a source for a replacement tweeter speaker with comparable specs? Unless I missed something, this article doesn't address that, and that's kind of an important piece of the puzzle.
You can get them from Aliexpress for about 10€.
How do I look for the speaker replacement, what characteristics should I indicate because I can't find it, greetings
