Ga door naar hoofdinhoud
Sonos One Protective Cover Replacement
Wat je nodig hebt
  1. Sonos One Protective Cover Replacement, Protective Cover: stap 1, afbeelding 1 van 3 Sonos One Protective Cover Replacement, Protective Cover: stap 1, afbeelding 2 van 3 Sonos One Protective Cover Replacement, Protective Cover: stap 1, afbeelding 3 van 3
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
    • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
  2. Sonos One Protective Cover Replacement: stap 2, afbeelding 1 van 3 Sonos One Protective Cover Replacement: stap 2, afbeelding 2 van 3 Sonos One Protective Cover Replacement: stap 2, afbeelding 3 van 3
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
  3. Sonos One Protective Cover Replacement: stap 3, afbeelding 1 van 2 Sonos One Protective Cover Replacement: stap 3, afbeelding 2 van 2
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
  4. Sonos One Protective Cover Replacement: stap 4, afbeelding 1 van 3 Sonos One Protective Cover Replacement: stap 4, afbeelding 2 van 3 Sonos One Protective Cover Replacement: stap 4, afbeelding 3 van 3
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
  5. Sonos One Protective Cover Replacement: stap 5, afbeelding 1 van 2 Sonos One Protective Cover Replacement: stap 5, afbeelding 2 van 2
    • Slide the protective cover upwards to remove.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Marcus Glowa
1.127 Reputatie
5 handleidingen geschreven
USF Tampa, Team S2-G1, Nance Spring 2018 Lid van USF Tampa, Team S2-G1, Nance Spring 2018
USFT-NANCE-S18S2G1
3 Leden
14 handleidingen geschreven
2Gids Commentaar
Well done! I would add a little bit about how much adhesive there is underneath the rubber feet as well as the screw cover.
Joshua Pinter - Antwoord Deel
Thanks for the helpful instructions! Could you let me know where I can order the protective case?
Nick Geleedst - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 68
Altijd: 6,856
