Ga door naar hoofdinhoud
Solio CLASSIC2 Removing the Circuit Board
Wat je nodig hebt
  1. Solio CLASSIC2 Removing the Circuit Board, Disconnecting the Battery: stap 1, afbeelding 1 van 1
    • Turn off the device by pressing on the clear power button behind the device.
    • To make sure that it is off, make sure the button is not flashing green.
  2. Solio CLASSIC2 Removing the Circuit Board: stap 2, afbeelding 1 van 1
    • Using the Phillips #1 screwdriver, remove the 2mm screw located on the bottom of the device, near the hinge.
  3. Solio CLASSIC2 Removing the Circuit Board: stap 3, afbeelding 1 van 3 Solio CLASSIC2 Removing the Circuit Board: stap 3, afbeelding 2 van 3 Solio CLASSIC2 Removing the Circuit Board: stap 3, afbeelding 3 van 3
    • Using the plastic opening tools, gently pry open the side of the large panel.
    • Keeping the tool in, slowly slide the tool along the side of the panel.
  4. Solio CLASSIC2 Removing the Circuit Board: stap 4, afbeelding 1 van 2 Solio CLASSIC2 Removing the Circuit Board: stap 4, afbeelding 2 van 2
    • Rotate the device 180 degrees.
    • Make sure the opening on other side of the device does not snap closed.
    • Gently slide the plastic opening tool along the side of the panel.
  5. Solio CLASSIC2 Removing the Circuit Board: stap 5, afbeelding 1 van 2 Solio CLASSIC2 Removing the Circuit Board: stap 5, afbeelding 2 van 2
    • Do not fully pull apart the back panel from the device. Doing so can rip the two red and blue wires attached to the panel.
    • Using both hands, slowly pull apart the back panel from the rest of the device.
    • Gently flip the back panel open so the circuit board faces up and the two panels are side by side.
  6. Solio CLASSIC2 Removing the Circuit Board: stap 6, afbeelding 1 van 2 Solio CLASSIC2 Removing the Circuit Board: stap 6, afbeelding 2 van 2
    • Softly pinch the red and blue wires close to the white connector.
    • To pull the wires out, wiggle them back and forth until the connector is fully out.
  7. Solio CLASSIC2 Removing the Circuit Board, Circuit Board: stap 7, afbeelding 1 van 1
    • Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
  8. Solio CLASSIC2 Removing the Circuit Board: stap 8, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Make sure the white USB port cover on the side of the device is pulled out or you won't be able to lift the circuit board.
    • Gently lift the circuit board out of the device using tweezers.
Conclusie
Eric Padilla
201 Reputatie
2 handleidingen geschreven
Cal Poly, Team 4-28, Amido Fall 2013 Lid van Cal Poly, Team 4-28, Amido Fall 2013
CPSU-AMIDO-F13S4G28
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 255
