Ga door naar hoofdinhoud
Sol Republic Deck LED Lights Replacement
Wat je nodig hebt
  1. Sol Republic Deck LED Lights Replacement, LED Lights: stap 1, afbeelding 1 van 2 Sol Republic Deck LED Lights Replacement, LED Lights: stap 1, afbeelding 2 van 2
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Insert the tip of a plastic opening tool or spudger into the the middle groove along the edge of the device.
    • Insert another opening tool into the groove to hold the front plate up as you separate both plates on all sides. Use multiple opening tools to keep plates separated if necessary.
  2. Sol Republic Deck LED Lights Replacement: stap 2, afbeelding 1 van 2 Sol Republic Deck LED Lights Replacement: stap 2, afbeelding 2 van 2
    • Using a PH00 screwbit, unscrew the two three-tenth cm screws and remove them.
    • Once the screws have been removed, lift the SOL plate revealing the LED Light strip.
  3. Sol Republic Deck LED Lights Replacement: stap 3, afbeelding 1 van 1
    • Using a PH00 screwbit, unscrew the two three-tenth screws that hold down the LED light strip at both ends.
  4. Sol Republic Deck LED Lights Replacement: stap 4, afbeelding 1 van 1
    • Using a PH00 screw bit, unscrew the three screws that hold down the motherboard.
  5. Sol Republic Deck LED Lights Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use tweezers and fingers to lift tab and ZIF (zero insertion force) connecter.
  6. Sol Republic Deck LED Lights Replacement: stap 6, afbeelding 1 van 1
    • Once unscrewed, the LED light requiring repair can be accessed by lifting up the entire LED light strip with tweezers.
  7. Sol Republic Deck LED Lights Replacement: stap 7, afbeelding 1 van 1
    • If you pull the LED light plate too hard, then the motherboard will snap in half.
    • Lift the LED light plate attached to the motherboard off.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Kristina Patel
137 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 7
Altijd: 2,123
