Inleiding
The SodaStream Source is battery operated. But If you are experiencing trouble with your device, and you have replaced the battery, it could be the microchip needs to be replaced. This guide will assist you in removing the carbonation block to access the microchip and replace it.
Wat je nodig hebt
Remove the soda bottle and the CO₂ canister from the machine.
Gereedschap gebruikt in deze stap:Phillips #1 Screwdriver$8.99
Remove the four 17.8 mm screws from the bottom metal base using a Phillips #1 screwdriver.
Remove the two 18.2 mm screws from the bottom of the front cover using a Phillips #1 screwdriver.
Één andere persoon heeft deze handleiding voltooid.
4Gids Commentaar
Great information, but is there someone out there offering this repair as a service, I’m not motivated enough to do this myself and happy to pay someone to do it for me
Where can you purchase a replacement microchip from?
Where can I find the reassemble source at
