Ga door naar hoofdinhoud
SodaStream Fountain Jet A200 Spring Replacement
  1. SodaStream Fountain Jet A200 Spring Replacement, removing back cover: stap 1, afbeelding 1 van 2 SodaStream Fountain Jet A200 Spring Replacement, removing back cover: stap 1, afbeelding 2 van 2
    • Press in the two gray buttons found on either side, at the top of the machine.
    • Pull back on the cover until it releases from the device and pull the back off.
  2. SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: stap 2, afbeelding 1 van 2 SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: stap 2, afbeelding 2 van 2
    • Place your hand under the carbonation button and gently pull up and away from you, towards the back of the machine.
  3. SodaStream Fountain Jet A200 Spring Replacement, spring removal: stap 3, afbeelding 1 van 2 SodaStream Fountain Jet A200 Spring Replacement, spring removal: stap 3, afbeelding 2 van 2
    • Remove the spring located under the carbonation button.
    • Replace with the new spring, by lining it up and pushing it down.
Conclusie
5 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Does anyone know where I can get a carbonation button?
draganr@wi.rr.com
draganr - Antwoord
Do we know the spring parameters?
Outside Diameter
Inside Diameter
Overall Length
Wire Diameter
Total # of Coils
Active # of Coils
Solid Height
Space between the Coils
John Friedman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 69
Altijd: 9,947
