Inleiding
There are 4 side switches on the phone. One controls the volume, the second toggles between AM and FM radio. Another switch turns the flashlight on and off, and the last switch locks and unlocks the phone.
Wat je nodig hebt
Turn off the phone to prevent data loss.
Press and slide the battery out to remove it.
Remove the four rubber inserts from the screw holes using a pair of tweezers.
Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
Separate the front case from the back case.
Remove the metal bumper from the front case’s perimeter.
Separate the circuit board from the inside of the back case by prying between them with the opening tool.
The last picture is a view of the back of the circuit board.
All three of these switches (shown in the red boxes in these two pictures) are removed the same way. So this guide will show the removal and repair of only one switch.
