Ga door naar hoofdinhoud
Snapfon ez One SIM Card Replacement
Wat je nodig hebt
  1. Snapfon ez One SIM Card Replacement, Remove the battery cover: stap 1, afbeelding 1 van 1
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Snapfon ez One SIM Card Replacement, Remove the battery: stap 2, afbeelding 1 van 1
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
  3. Snapfon ez One SIM Card Replacement, SIM Card: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the tweezers,if needed, to grasp the SIM card for removal. Apply a slight pulling tension and remove it from under the tabs as shown.
Conclusie
To reinsert the SIM card or a new SIM card, position the card in the same orientation seen in the figure with the brass connections facing the phone while using thumb to apply a slight force until the card rest inside of the recessed holder. Make sure the brass contacts of the card and phone connect. Then follow the steps in reverse order to reassemble phone.
John Bender
818 Reputatie
8 handleidingen geschreven
Clemson, Team 6-5, Benson Spring 2014 Lid van Clemson, Team 6-5, Benson Spring 2014
CLEM-BENSON-S14S6G5
3 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 1,171
