Ga door naar hoofdinhoud
Smartab STJR700 Screen/Digitizer Replacement
Wat je nodig hebt
  1. Smartab STJR700 Screen/Digitizer Replacement, Screen/Digitizer: stap 1, afbeelding 1 van 2 Smartab STJR700 Screen/Digitizer Replacement, Screen/Digitizer: stap 1, afbeelding 2 van 2
    • There are four screws with each one in each corner. Use the screwdriver to unscrew the back or bottom of the device.
  2. Smartab STJR700 Screen/Digitizer Replacement: stap 2, afbeelding 1 van 1
    • Remove the bottom or back of the device by detaching the black bottom after removing the screws.
    • the front panel should now be exposing the digitizer along with the other electronic components of the device.
  3. Smartab STJR700 Screen/Digitizer Replacement: stap 3, afbeelding 1 van 2 Smartab STJR700 Screen/Digitizer Replacement: stap 3, afbeelding 2 van 2
    • Next, remove the circuit board from the front panel and screen. This should leave the digitizer and circuit board intact.
    • Afterward, remove the existing damaged glass part of the device from the front panel as shown in the last picture.
    • Finally add a new STJR700 screen and reverse the previous steps to reattach the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tianna Edwards
128 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S3-G4, Botvin Spring 2017 Lid van UMass Dartmouth, Team S3-G4, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G4
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 1,130
