Ga door naar hoofdinhoud
Smart Tweezers and LCR-Reader LCR-meter Screen Replacement
Wat je nodig hebt
  1. Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Opening the device: stap 1, afbeelding 1 van 2 Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Opening the device: stap 1, afbeelding 2 van 2
    • Start by removing the 4 screws in the back of the device using a size 00 Philips screw driver.
  2. Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Replacing the screen: stap 2, afbeelding 1 van 2 Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Replacing the screen: stap 2, afbeelding 2 van 2
    • Gently open the zif connector that holds the screen.
    • Insert the replacement screen, and close the zif
  3. Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Closing the device: stap 3, afbeelding 1 van 1
    • When closing the housing, make sure the screen fits into the rectangle on the top.
    • If the screen is not in this rectangle, it may become damaged when the screws are tightened
    • Hold the screen in place from below; line up the button's edge of the top housing to line up with the bottom housing. Slide your finger out as you bring the top and bottom housings to meet.
    • Replace the 4 Philips screws in the back.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
brittany
234 Reputatie
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 552
